2001 Cavalier is there a Fan Relay switch?
Google
Web AF
buzzman
03-17-2008, 10:22 AM
my 2001 cavalier overheats only when it idles, overheats in 3 to 5 minutes & the ac blows hot. As soon as you get moving again the car runs at normal temp and the ac blows ice cold. We changed the thermostat, coolant and belts, i'm not loosing any coolant. Looks like the fans are not coming on, I can not find a location for a fan relay switch, thought maybe we should change that before changing out the fans..Is there a relay switch? any one have any other ideas?
kezia
03-17-2008, 11:13 AM
the fan motor could be shot.
brcidd
03-17-2008, 12:36 PM
Look in underhood fuse/relay center- pull fan relay-- "jumper" the relay and see if fan comes on- if not- then pull fan connector at fan- jumper it there- if fan is still inop- you need a new fan motor
Jacfourteen
03-18-2008, 01:02 AM
Or you could just rob the relay from another location, like the fog light relay. If you are running the ac then the fan should automatically come on. so if you swap relays and the fan still doesn't run then you have a bad fan or bad wiring, chaeck for power at the fan connector.
jakegday
03-18-2008, 10:43 AM
your a/c is working like its supposed to, when it senses no air flow going through the condenser it quits working, thats what is happening in your case, now you just need to find out why there is no air flow, obviously you know the fan isnt kicking on and just need to fix that,
yes there is a relay, when i had your IDENTICAL problem it ended up being a $4 fuse that had blown, the one under the hood for the radiator fan, turns out it blew when i went through some pretty deep water a few nights before, i also had a check engine light with that problem
farmvillebill
03-28-2008, 08:06 PM
I do not mean to "Hijack" but I am having similar problem and saw this thread, may be helpfull to me. Mind me asking how do you "Jump" the relay?
brcidd
03-28-2008, 10:12 PM
A four legged relay has 2 legs for the coil and 2 legs for the "switch" - so you merely connect the two sockets that are the "switch" that the relay plugs into usually with a paper clip- a bosch style relay uses "87" and "30" as the leg identifiers for the switch- or you can meter your relay socket- there will be two 12 volt battery hots- the one is for the coil the other is the feed for the compressor- the feed for the compressor needs to be "jumpered" to the socket that leads to the compressor....
Google
Web AF
