1978 Mgbrick1954 03-17-2008, 09:34 AM I replaced the coil in my 1978 MGB And I need help with the wire connections to the coil. I think it is not the correct distribtor because it has points. I have Green & White wires, Black & white wires, the wire from the points to the coil and a white wire that is a positive hot wire. Can someone let me know what treminals on the coil the wires should be placed ? Thanks! KimMG 03-19-2008, 11:52 PM Wiring diagrams are available at http://www.advanceautowire.com click on stock schematics. Flash75 03-20-2008, 05:46 AM Is your coil a 1.5 ohm (6v) coil for use with a ballast resistor? Or is it a 3 ohm (12v) coil for use without a ballast resistor? The type coil you have determines how it should be hooked up. The wiring diagram will not be correct if you have a points type distributor. Let us know which coil you have. The coil should have a label stating if it needs a ballast resistor. Clifton vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
