96 Camry Code P0401srip72 03-16-2008, 09:24 PM recently i got installed a egr valve and the tubing. I used my obd to check for any codes and it reads p0401. Why is still reading that as a problem when there is a new egr valve installed? Brian R. 03-16-2008, 10:56 PM Could be any of the following instead of the EGR valve: EGR Vacuum Switching Valve (VSV) Open or short in VSV circuit for EGR EGR valve position sensor open or short circuit Vacuum or EGR hose disconnected EGR valve position sensor Manifold absolute pressure sensor malfunction beckeja 03-19-2008, 10:10 PM Replaced mine a few months ago the egr VSV. Tried replacing egr and did not fix the PO401 code on my camry. About $70 for the part at the dealer. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
