98 z71 wheel locked up2percent 03-09-2008, 01:13 PM My dad came to visit and he drove his truck up here to Ohio. well we gat alot of snow but no problem its 4wd. Now the problrm the drivers side rear tire wont spin the other tires all do but it wont spin what could be the problem? tempfixit 03-09-2008, 02:03 PM Can you give us more info? what do you mean by not spinning? Do you mean the wheel will not turn and drags while vehicle is in motion? Have you jacking the right rear wheel off the ground and tried turning the wheel while transmission is in neutral? Disk brakes or drum brakes on the rear? Has the parking brakes been used lately? 777stickman 03-09-2008, 08:30 PM Most likely the '98 has rear drums. If so and it was driven in snow and parked with the parking brake on and then froze. Take a hair dryer to it and hope that works. 2percent 09-20-2008, 10:16 AM it was the rear end locked up j cAT 09-20-2008, 11:05 AM it was the rear end locked up thanks for the result of wheels locked..what was the cause of failure...wheel bearing /driveshaft seals...or lack of regular maintenance? 2percent 09-20-2008, 11:35 AM thanks for the result of wheels locked..what was the cause of failure...wheel bearing /driveshaft seals...or lack of regular maintenance? some how water got in there and it froze and broke something vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
