push-button starter
Google
Web AF
thabadguy
03-08-2008, 12:04 AM
i want to put a push button starter instead of the key on my 89 rs v6, but i want the key to control everything but the starter. how do i wire it. help plz..
GreyGoose006
03-08-2008, 09:15 AM
well i dont think that what you want is gonna be easy at all.
you might be best to install a remote start system, then wire a direct link to the unit with a on off momentary switch instead of using the key fob they give you.
idk.
for remote start to work, you have to have the key in to drive, but not to start.
the way it works i believe is that if you want to take the car out of park, you have to push the brakes, and if the key isnt inserted when you push the brakes (or clutch i suppose) it shuts the car off.
jdl
03-08-2008, 11:31 AM
You could run a circuit to the ignition terminal at the starter solenoid. Use the starter button in series on that circuit. That will crank the starter even without a key. THERE ARE SAFETY ISSUES, doing it that way. It will bypass the clutch switch or neutral safety switch. It will crank no matter what gear it's in. You could wire it through the clutch or neutral switch. I was looking through a Dell City automotive electrical products catalog. They have starter buttons. Is it safe to wire a starter to crank no matter what gear it's in, or whether or not the clutch is depressed, probably not. You've probably forgotten more about vehicles than I'll ever know, but, you need to be careful with what your trying to do.
Anybody remember the old vehicles with starter button on the floor. Most of the ones I remember were manual trannies, If the vehicle was in gear and you hit the starter button without pushing in on the clutch, the vehicle goes to moving, didn't even need a key.
thabadguy
03-08-2008, 02:54 PM
i already got my button and theres two termanils on it which is power and ground.
Google
Web AF
