97 dohc (special edition POS model) z34 3.4
meow700
03-05-2008, 04:28 PM
SO i have oil spraying from the number one spark plug hole from underneath the rubber boot. It's overheating also. Oil level not low, antifreeze level not low. No liquids leaking from any other place in the motor, i was thinking head gaskets now im thinking upper intake gaskets, haven't ruled this out yet, now im thinking of setting fire to it. Any Suggestions on what the problem is.
blazes9395
03-06-2008, 03:40 PM
I don't understand, is it coming from the spark plug hole, like oil bubbling up?
meow700
03-07-2008, 06:06 PM
yes, it is actually spewing out of the sparkplug hole on the motor
blazes9395
03-08-2008, 12:39 AM
Check the gaskets. The upper portion of the head on these engines is bolted to the bottom portion. That sounds like where your leak is coming from. Pull the valve cover off and you should have a better view of this.
