door lock/window/mirror buttons died
Google
Web AF
outcold
03-03-2008, 05:18 PM
hi all. im new here. i own a 01' silverado 4x4 ext cab. it has 105,000 miles on it. about 2 months ago my drivers door became useless. none of my buttons work. i've tried finding threads on this and found some, but does anyone know what i need to buy to fix this? im also not very auto savvy, thx alot
J-Ri
03-03-2008, 05:40 PM
Welcome to AF!
Your door is not useless, it still keeps you in and the weather out! :biggrin:
Start by checking all the fuses (probably not the cause if only one door is inop, but always start with the basics. You'll probably need a wiring diagram to test it. It seems to me that they are three seperate switches (and it's very unlikely for three parts to fail at the same time) mounted in a common trim piece, but I have been wrong before. Does the power lock work on the drivers door if the switch is pressed on the passenger door?
outcold
03-04-2008, 10:14 AM
ok, the fuses and relays are fine. the passangers door lock works for both doors. my fob works for both doors lock/unlock. so now what?
Tdragone
03-05-2008, 12:25 AM
Do you know how to use a multimeter to test voltage?
It sounds like the shared positive or negative wire isn't connected anymore...
outcold
03-05-2008, 08:45 AM
no... my dad is coming over saturday to help me with it. so ill learn how too use it then. ill let you guys know. thanks
Google
Web AF
