replacing water pump
Google
Web AF
Sublime69
03-03-2008, 03:53 PM
well my water pump started leaking out of the weep hole. The re manufactured water pump does not come with the pulley, does any one know how to remove the pulley??? oh, ya i have a 99 silverado 5.3
J-Ri
03-03-2008, 05:44 PM
Two ways...
1) position a prybar, screwdriver, or a special tool designed for it between two of the bolts to keep the pulley from turning while you loosen (but do not remove) one bolt, repeat 3 more times. Once they're all loose, remove them completely.
2) Use an air ratchet (or impact wrench if space allows). With the air ratchet you pull or push to keep the socket in the same spot as the bolt turns. With the impact wrench, it goes so fast that the weight of the pulley keeps it from spinning
Sublime69
03-03-2008, 07:30 PM
its a pressed on pulley, no bolts
j cAT
03-03-2008, 08:13 PM
remove fan clutch nut right hand reverse threads then....
you use 4 bolts to push off the pulley from shaft of water pump.... do you see 4 holes in pulley ? you place bolts in those holes then tighten to force off pulley.. .. when removing nut do so with belt on......
Sublime69
03-03-2008, 09:43 PM
yes, it does have 4 holes, are the holes threaded?? Also when i go to put it on the new pump, do i just use a mallet or hammer?
chuck16
03-04-2008, 11:09 AM
Wow, I'm surprised it didn't have a pulley? Mine had a pulley but the hard part was getting the mount for the Fan Clutch Assembly off. I ended up buying a belt wrench and big Crescent wrench to get that nut off. Are you sure it's the right Pump? My 99 just went as well about a month ago and it came with the pulley...
Just my 2 cents worth.
brcidd
03-04-2008, 12:54 PM
The ones I get come with the pulley already on them....I think you have the wrong one..
j cAT
03-04-2008, 02:16 PM
the big nut is torqued to 40ft lbs...
j cAT
03-04-2008, 02:18 PM
where did you purchase this water pump ?????
Sublime69
03-06-2008, 01:23 PM
I bought it from a murrays discount auto.
Sublime69
03-06-2008, 01:24 PM
where did you get yours from? and how much was it??
rockwood84
03-07-2008, 12:07 PM
the nut on the fan will come loose if you put the wrench on it and hit the wrench with a hammer to act as an impact would . if this doesn't work try putting a wedge of wood between pullies the pop the wrench with a hammer .on an 'o2 8.1 the nut loosens to the left.and do not lay the fan down when you take it off stand it up.
chuck16
03-10-2008, 10:39 AM
Hey Sublime,
I got mine from Lordco and it was $198 CAN...
Evan
Google
Web AF
