eagle problem
klapanther
03-02-2008, 08:31 PM
:banghead: :banghead: :banghead: i have a 95 eagle talon ESI and it will not crank or turnover i just replaced the battery thinking that was it but it did nothing still the same cant seem to find outt the problem im thinking its my computer but im really hopeing its not:banghead: :banghead: :banghead:
david-b
03-02-2008, 08:41 PM
Hi and welcome to AF. Have a couple questions for you.
Does anything electrical work? Do the headlights turn on? When the key is in and cranked do any of the dash lights come on?
When you crank, does the starter click, buzz or make any noise at all?
steviek
03-02-2008, 09:47 PM
also if it is the ecu don't fret they aren't that expensive and easy to swap
SilvrEclipse
03-02-2008, 10:26 PM
klapanther - Welcome to AF, please use a little bit better grammar when making a thread. Not that we are picky about everything but it makes it hard to read and understand your problem. Remember that the better you discribe your problem the easier/faster it will be to solve it.
Micjohvan
03-03-2008, 12:19 AM
Bad starter maybe? But yes, if its the ECU they are not hard to replace at all really (at least on the 1gens I have done it on)
JoeShmoe
03-03-2008, 06:55 AM
Welcome to AF, yeah also don't forget to add your car info and mods as asignature.
klapanther
03-03-2008, 05:30 PM
well im looking for body kit, head lights and tail lights hopeing to keep the talon center peice just want to change the outer ones, also a spoiler and a pair off seats ohh yeah a new hood
steviek
03-03-2008, 06:02 PM
that is wayyy to vague of a question you have to specify what parts you are looking for and then we can point you in the right direction.
Black99GST
03-05-2008, 01:56 AM
might wanna try and get the car started first??? IMO... i could be wrong though...
:screwy:
anyway my :2cents::
if anything electrical works (lights!!!) i'm going to go with the starter! can you here any relays when you try to start the car? any noise at all? more info on this would get you an answer MUCH faster...
:screwy:
anyway my :2cents::
