New lifters...need help
Google
Web AF
bowtieboy12
02-25-2008, 06:11 AM
I have a '99 2.2L 2WD. My truck is in need of new lifters as it is making a horrible clanking noise. I was pretty sure this was the issue, and I had it confirmed at a shop. However, they want almost $1000 to fix it. I think I can fix it, it will just take some time.
Has anybody done this themselves before? How do I go about it? Apparently with this engine the lifters come out through the bottom. Any and all help is greatly appreciated.
j cAT
03-03-2008, 08:40 PM
what is the oil pressure...? if one lifter makes noise ok ... but if all make noise sounds like oil pressure....
bowtieboy12
03-11-2008, 08:23 PM
I have noticed a drop in oil pressure. The pressure used to be around 75-78 for the first 10-15 miles. Now the pressure only hits 60 if the RPM's are high. Is there maybe another problem?
j cAT
03-11-2008, 08:46 PM
your oil pressure of 60 psi after 5min of engine cold start is normal... 80 psi is only when the engine is very cold... are you using 10-30wt....also are you sure the engine has the correct oil filter and who makes it..did you replace lifter/s?
bowtieboy12
03-13-2008, 06:56 PM
Have not installed new lifters yet. Its making quite a racket. Loud metallic banging.
The oil and filter are correct.
Google
Web AF
