In the garage all day todaybpddaddy 02-16-2008, 09:01 PM Bled the brakes, Transfer case fluid, differentials done, and aggressive front pads put on a 2001 Tahoe. Get this. I had the brake fluid flushed yesterday at my stealer here in Sacramento, CA. After bleeding the brakes, at least a quart of dark brake fluid came out. I'm thinking they didn't flush the system. What do you guys think. Also had U-joints replaced and some wonderful mechanic did not fully replace the rubber cover from the joint going into the Transfer case. Plus they scratched the hood and bumper I'm going back on Monday!! j cAT 02-16-2008, 09:24 PM Bled the brakes, Transfer case fluid, differentials done, and aggressive front pads put on a 2001 Tahoe. Get this. I had the brake fluid flushed yesterday at my stealer here in Sacramento, CA. After bleeding the brakes, at least a quart of dark brake fluid came out. I'm thinking they didn't flush the system. What do you guys think. Also had U-joints replaced and some wonderful mechanic did not fully replace the rubber cover from the joint going into the Transfer case. Plus they scratched the hood and bumper I'm going back on Monday!! this is the norm bring it to stealership for repairs and they create more problems ""been there and back too many times'''..... if you bring it back , they will break something else..........good luck!!!! mmoss10 02-16-2008, 10:10 PM Dealership techs these days only know how to hook up a scanner. Mr Goodwrench passed away a long time ago. :headshake vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
