99 lx whistling,hissingjamesmetairie 02-13-2008, 02:18 PM especially after driving above 40mph. as it comes to a stop sign you can hear it fade out. vacuum leak? maybe this is the reason for the rough idle car has when parked with motor running in gear(drive). Davescort97 02-13-2008, 06:48 PM It sure could be a vacuum leak. I guess from reading your posts you've ruled out everything else. To find it pinch off the vacuum hoses coming off of the intake plenum with a pair of needle nose pliers and those hoses that are on the vacuum block behind it. If you find a leaker the idle will improve, then you can trace it back until you find the leak. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
