Whats that knock?
rob's garage
02-11-2008, 08:36 AM
84 box style caprice with a newer 99 vortec. Left bank has a knocking sound that comes and leaves depending on accelaration. When i decellarate it began, if i softly step to acell it goes away. this happens when at high speeds. can anyone help?:banghead: sorry for the misunderstanding, its a vortec out of a 99 tahoe.
96capricemgr
02-11-2008, 10:25 AM
What is a "newer 99 LT1"?
There was a 4.3L version of the LT1 called an L99 that was a V8, and the LT1 was only used through 97.
To it sounds like it has a rod knock. Is it a deep tone or more clattery?
silicon212
02-11-2008, 11:13 AM
The L99 was only ever installed in the Caprice. It was '94-'96.
96 is right, the last year of the LT1 was '97, and that was in the Camaro/Firebird.
I'll second the rod bearing theory.
bobss396
02-12-2008, 10:15 AM
If the thing is still running strong, it could be a wrist pin. They give off a "double knock" and is a little more of a clatter. See if you can isolate it to a single cylinder by removing one spark plug wire at a time and going for a ride. The knock usually lessens when it is not under compression.
Bob
rob's garage
02-16-2008, 03:26 AM
thank you for your input.
