R33 GTS-4 Driveshafts
R33 GTS-4
02-11-2008, 02:58 AM
hay all,
Ive got a question the driveshafts on the r33 gts4 and i was wondering if you could runn the gearbox with out the driveshafts so it just rear wheel drive? or should i just go and buy a r33 gts gearbox?
thanks heaps if u can help.
mmcleo11
03-21-2008, 12:42 AM
You can disconnect the ATTESA transfer case wiring to revert it back to RWD. Check skylinesaustralia.com for more info :)
Madaz_
03-25-2008, 03:20 PM
yeah it can be done 5 mins job
you need a hoist and some spanners take the shaft out from the transfer case you dont need to plug the hole nothing comes out
then pull the AWD fuse out of the fuse box in the boot the top of the plastic cover will tell you which one to pull
