O2 sensor on 96 sentra
View Full Version : O2 sensor on 96 sentra O2 sensor on 96 sentra danger81 02-04-2008, 04:01 PM nismo_pilot 02-04-2008, 09:48 PM its different, the rear o2 sensor is a catalyst efficiency monitor and does nothing for your car but tell it if the cat is working slideways... 02-06-2008, 08:51 PM probably the CEL is a result of a different issue that is causing too much gas to be injected, thus fouling up the spark plugs, cat, and oxygen sensors. i would make an attempt to figure out and fix your driveability problem or else you may be stuck replacing both 02 sensors and the cat more than once. Related Links Participate in thousands of discussions at AutomotiveForums.com! Registration is absolutely free. |
