95 DelSol stalls when temperature nears operating temp
ausikdar
01-30-2008, 11:21 AM
Hi,
I have a 95 DelSol S which recently starts stalling for a half a minute or so when temperature nears the operating temperature, i.e. temperature gauge rises to the operating temperature, and then everything is back to normal. I have replaced the radiator, spark plugs/wires, distributor rotor/cap. The engine runs strong otherwise and it does not have any idling problem. The heater works fine and temperature gauge rises maximum to just below the middle. Please help me.
danielsatur
04-05-2008, 01:50 PM
1) I have had a problem with a mustang years ago,and it was the electronic
Iginition module on distribuitor.
2)A bad coil can cause the same problem!
When heat go's up in a coil,the inductance reactance go's down.
The voltage might not step up thus cause a misfire.
Note: Every time the engine would get Hot,I would lose the Timing!
GOOD LUCK! :smokin:
MCGIVER
GOOD LUCK! :smokin:
MCGIVER
