Still getting P0430 CodeBlazin56 01-29-2008, 07:32 AM 99 Tahoe with 124k. Been throwing code for some time. P0430 Cat. effeciency below threshold bank2. Replaced both O2 sensors, installed aftermarket cat. and replaced the fuel pressure regulator. Truck runs pretty well, not much powerloss but I am still stumped. Have state emissions due next week and I need some help. the SES light comes on for a day or so, then goes out for a day, but never goes out for good. Just recently changed my rear O2 sensor and no help. I did notice while checking for leaks that the rear cat. gasket was spewing out alot of exhaust. Would this throw the code now? I need some major help guys, strung out mentally and financially. Thanks guys Headnsouth 01-29-2008, 08:03 AM Maybe this will help: Sorry I can't attach pics Subject: Information on Engine Misfire MIL/SES Light Illuminated or Flashing DTC P0300, P0301, P0302, P0303, P0304, P0305, P0306, P0307, P0308, P0420 or P0430 #06-06-04-046 - (09/12/2006) Models: 1999-2007 Cadillac, Chevrolet, GMC Full-Size Pickup and/or Utility Trucks with 4.8L, 5.3L, 5.7L, 6.0L or 6.2L VORTEC GEN III, GEN IV, V-8 Engine (VINs V, C, T, Z, B, 3, M, 0, J, R, U, N, Y, K, 8 -- RPOs LR4, LY2, LM7, L59, L33, LC9, LH6, LMG, LY5, L31, LQ4, LQ9, L76, LY6, L92) with Active Fuel Management™ and E85 Flex Fuel -------------------------------------------------------------------------------- If you encounter vehicles that exhibit the above conditions, refer to SI for the appropriate DTC(s) set. If no trouble is found, the cause may be due to an ECM ground terminal that has corroded with rust over time. Inspect the main engine wiring harness ground terminal (G103) for this condition. The wire terminal (G103) attaches either to the front or to the rear of the right side cylinder head, depending on the model year of the Full Size Pickup and/or Utility Trucks. If the ECM ground terminal has been found to be corroded, then follow the service procedure outlined in this bulletin to correct the corrosion issue. Engine Wiring Harness Ground Terminal Location (2007 Full-Size Pickup and/or Utility Trucks) Engine Wiring Harness Ground Terminal Location (1999-2006 Full Size Pickup and/or Utility Trucks) Remove either the nut or bolt securing the main engine wiring harness ground terminal (G103) to the right cylinder head. Refer to the above illustration to determine where the ground is located on the vehicle (1). Remove all rust from the ground terminal, the cylinder head and the retaining nut or bolt. Position the main engine wiring harness ground terminal and install the nut or bolt. Tighten: Tighten the retaining nut or bolt to 16 N·m (12 lb ft). Apply some type of electrical moisture sealant to protect the harness terminal from further corrosion. Blazin56 01-29-2008, 09:25 AM Thanks Headnsouth, I will give that a try! MT-2500 01-29-2008, 10:47 AM Thanks Headnsouth, I will give that a try! Go over the tsb real good. But Remember most cat codes are caused by engine running rich or missfires. Make sure the tune up end and engine running is good. Good Ac delco plugs? http://www.troublecodes.net/articles/catfailure/ Here is a little info on cat codes. DTC P0420, P0421, and P0430 & P0431: Check Possible Cause Of Misfire DTC P0420 and P0421 indicate bank one catalyst system efficiency is minimum requirement. DTC P0430 and P0430 indicate bank 2-catalyst system efficiency is minimum requirement. Possible causes are as follows: Use of leaded fuel. Oil contamination. Cylinder misfire. Fuel pressure too high. HO2S sensor improperly connected. Damaged exhaust system component. Faulty ECT sensor. Faulty HO2S. Ensure ignition timing is correct. Retrieve all Continuous Memory DTCs. If misfire code is not present, go to next step. If misfire code is present, isolate cylinder and repair as necessary. Check HO2S Monitor DTCs If DTCs P0136, P0138, P0140, P0141, P0156, P0158, P0160, or P0161 were present in step 1), service as necessary before continuing. If none of these codes are present in step 1), go to next step. Check ECT Sensor DTCs If DTCs P0117, P0118, P0125 or P1117 were present in step 1), service as necessary before continuing. If none of these codes are present in step 1), go to next step. If any codes except P0420, P0421, P0430 and/or P0430 were present in step 1), service as necessary before continuing. If no codes except P0420 and/or P0430 were present in step 1), go to next step. Check Rear HO2S Wiring Harness Turn ignition off. Ensure HO2S wiring harness is correctly routed and connectors are tight. Repair or replace as necessary. If wiring harness and connectors are okay, go to next step. Check Fuel Pressure Turn ignition off. Release fuel pressure. Install fuel pressure gauge. Start engine and allow to idle. Note fuel pressure gauge reading. Increase engine speed to 2500 RPM and maintain for one minute. For fuel pressure specifications, see FUEL PRESSURE SPECIFICATIONS article. If fuel pressure is as specified, go to next step. If fuel pressure is not as specified, go to CIRCUIT TEST HC. Check For Exhaust System Leaks If exhaust system leaks, it may cause catalyst monitor efficiency test to fail. Inspect exhaust system for cracks, loose connections or punctures. Repair or replace as necessary. If exhaust system is okay, go to next step. Check For Exhaust System Restrictions Inspect exhaust system for collapsed areas, dents or excessive bending. Repair or replace as necessary. If exhaust system is okay, go to next step. Check Manifold Vacuum Install tachometer. Connect vacuum gauge to intake manifold vacuum source. Start engine and raise engine speed to 2000 RPM. Manifold vacuum should rise to more than 16 in. Hg. If manifold vacuum is okay, go to next step. If manifold vacuum is low, go to step 11). Leave tachometer and vacuum gauge connected. Start engine and raise engine speed to 2000 RPM. On a non- restricted system, manifold vacuum should quickly rise to normal range as increased RPM is maintained. On a restricted system, manifold vacuum will slowly rise to normal range as increased RPM is maintained. If manifold vacuum is okay, no indication of exhaust leak or restriction has been detected and testing is complete. If manifold vacuum is low or slow to respond, go to next step. Leave tachometer and vacuum gauge connected. Remove exhaust pipe from exhaust manifold. Start engine and raise engine speed to 2000 RPM. If manifold vacuum is now okay, fault is downstream from exhaust manifold. Reconnect exhaust pipe to exhaust manifold and go to next step. If manifold vacuum is still low or slow to respond, fault is in exhaust manifold or intake manifold gasket. Repair or replace as necessary and repeat QUICK TEST. Leave tachometer and vacuum gauge connected. Disconnect muffler/tailpipe assembly from rear of catalytic converter. Start engine and raise engine speed to 2000 RPM. If manifold vacuum is now okay, fault is in muffler/tailpipe assembly. Repair or replace as necessary and test-drive vehicle to verify elimination of symptom. If manifold vacuum is still not okay, fault is in catalytic converter. Repair or replace as necessary. Check tailpipe/muffler assembly for debris from catalytic converter. Test drive vehicle to verify elimination of symptom. j cAT 02-03-2008, 09:34 AM I did notice while checking for leaks that the rear cat. gasket was spewing out alot of exhaust. Would this throw the code now? I need some major help guys, strung out mentally and financially. Thanks guys[/quote] any manifold / exhaust leaks will throw off the sensor response. fix the exhaust leak. if no money use patch kit. make sure all sensor wires and sensor are clean with no grease or oil contamination on exterior......... vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
