Rpm"s
thisismylife
01-24-2008, 11:11 PM
I have a 87 Cherokee 4’ lift 32x11.5 tires 4.0 I have low rpm and some time on ice if I spin out when It get traction it wants to die any ideas
citizen@large
01-26-2008, 10:21 AM
Have you changed your gearing to match the tire size? Is she auto or manual? Other chages/repairs recently? (since bigger tires) Need some background here..
thisismylife
01-26-2008, 11:42 PM
She is a auto when I got the jeep all work was don I put the crawly hood on it he said it was geared
but can not says for sure thanks ill try to find out it out thanks
thisismylife
01-27-2008, 12:05 AM
Ok I just got off the phone with the guy I got the jeep from and he says was not geared for tire so what will it do the the rig with out being done thanks
sector95
01-27-2008, 08:16 AM
Ummm...exactly what you're getting now. Sticking mongo tires (larger overall diameter) on your ride and *not* regearing the rear axle will effectively raise your final drive ratio....this in turn will make your once half spritely XJ turn into a stone. Raisng the final drive ratio means the engine is working against taller gears. You will also screw up your speedo; it will read lower than what you're actually doing...so beware the speed traps. You're mileage (MPG), which is not a strong suit of the XJ to begin with, will really fall into the crapper. Regearing the rear end is a little tricky; it requires care, skill and patience to do it right so make sure whoever is gonna do it does this sort of thing often.
AlohaBra
01-27-2008, 11:08 AM
With 32s and stock gearing, some people just never use the D position in their automatic. They just drive it in 3.
Or you could manually shift it. Which is what I would do.
