Transmission Bolt RepairWags391 01-23-2008, 01:47 PM I once received a $500 tranny rebuild. I have since found out, that is exactly what I got. Two or three bolts now will not torque, obviously stripped out. What is the best way to go about repairing this? Re-thread or drill and re-tap with bigger bolts? 1992 S10 Blazer, 4.3L TBI, 4x4, 190,000 miles. marc-o-matic 01-23-2008, 02:43 PM MT-2500 01-23-2008, 05:21 PM I once received a $500 tranny rebuild. I have since found out, that is exactly what I got. Two or three bolts now will not torque, obviously stripped out. What is the best way to go about repairing this? Re-thread or drill and re-tap with bigger bolts? 1992 S10 Blazer, 4.3L TBI, 4x4, 190,000 miles. What bolts? Oil pan or tail end or other? MT Wags391 01-23-2008, 05:22 PM The bolts are to the trans oil pan. MT-2500 01-23-2008, 05:44 PM The heli coil kit as posted works good. Most parts places have them in stock. MT Wags391 01-23-2008, 08:55 PM The heli coil kit as posted works good. Most parts places have them in stock. MT Is it better to use a kit or to re-tap at a slightly larger thread size? MT-2500 01-24-2008, 10:16 AM Either way usualy works. And sometimes I have switched from metric to sae or the other way just screwed in a size larger bolt. But the next person that drops the pan will have to watch the different size bolt setup. The kit makes a good professional job. MT G.A.S. 01-24-2008, 10:32 AM http://www.amazon.com/Helicoil-5546-8-Thread-Repair-1-25/dp/B0002SREP4 this is the proper way to go. The only way, very profesional. I use these on all striped out threads. easy to install and the kit comes with the tap, instalation tool and several coils. the only thing I had to purches beyound the kit was a drill bit. replacing a 5/16 thread calls for a 21/64 drill bit. Use brake kleen spray and air to clean out the hold after it is drilled. On a few occations I used just the fast evaporating brake kleen to clean out the holes as I had no air handy. worked fine. Then, like mentioned, the next tine your not fumbeling with bolts. bobss396 01-24-2008, 11:11 AM If you can, make up a block to guide the tap drill and tap. Give both the tap and drill just a little clearance. Aluminum is preferred, but hard plastic or phenolic will do. I like to use something 1"-1.5" thick. This keeps the drill and tap straight. Mark the depth on your drill with a piece of masking tape so the depth is constant. If you can get a tap wrench handle ("T" type) this will make the tapping easier and less prone to breakage. Bob BennieBO 01-29-2008, 03:56 AM :cool: Hi you may want to look at this website (http://www.nes.co.il/Fastener_repair/index.html)they show tools that repair bolts and other threaded fasteners, but they do not create new fastener threads. What do you think ? vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
