1500 Truck ignition key cylinder Remove and Replace
Google
Web AF
fifty5chevy
01-22-2008, 10:56 PM
C/K 1500 Truck ignition key cylinder Remove and Replace proceedure needed, it has tilt steering wheel. the key sticks in the ON position.>thanks for the reply !
fifty5chevy
01-22-2008, 10:57 PM
I forgot to add --- its a 1993 Model Year.
jayman4pu
01-23-2008, 09:13 AM
I'm getting ready to do this same thing. I don't have my Hayne's manual here at work with me, but the procedure (along with their typically crappy pictures) is in there. I know you have to remove the steering wheel, but I don't think the tilt becomes a problem so long as you leave it alone after you've got it taken apart.
J-Ri
01-23-2008, 03:44 PM
Tilt wheel does not affect the lock cylinder removal
http://www.automotiveforums.com/vbulletin/t714776.html
To answer his question, which I don't remember seeing at the time, there is no easier way, and the key position doesn't matter. If it is out of the "lock" position, you can use the key to pull the cylinder out.
j cAT
01-23-2008, 03:53 PM
before you do this i have found worn keys will give this type of problem.......
'97ventureowner
01-23-2008, 04:14 PM
Is this a common issue with these trucks? I have a 1994 C1500 (non tilt wheel) and had the same problem back in 1996. Luckily it was replaced under warranty.
randy78
02-04-2008, 06:09 PM
common problem
replace it
new ones are cheap
have to remove steering wheel, lock plate, and pull the turn signal assembly up far enough to get to the screw or tang that retains the lock in the housing
most have a screw
some dont
torx bit
wheel/pulley puller and two bolts,
lockplate compressor tool
both tools 15 bucks autozone etc
good luck
Google
Web AF
