Keyless Entry Programming
Google
Web AF
sdunaway
02-21-2003, 03:20 PM
95 Chevy Lumina Van - How in the world do you program the new dealer-supplied keyless entry fob?
Shortbus
02-21-2003, 04:44 PM
I don't have this one ready to copy and paste so I will have to type it out. Will be right back:)
BTW:
<MARQUEE>WELCOME TO AF!:) </MARQUEE>
Shortbus
02-21-2003, 04:54 PM
Ok here it is. I did not proofread this so bear with me on the spelling and typo's. John
Programming the Remote Lock Control Receiver.
Each remote lock control receiver can be programmed with the security codes of up to four unique transmitters. The receiver must have at least one transmitter trained and stored into the non volatile memory for the system to operate remotley. Initially, two transmitters and one receiver will be shipped as a pre prgrammed set.
In the event that a transmitter is lost the security codes of previously prgrammed transmitters need to be deleted. The Right hand instument panel sound insulator panel and I/P compartment must be removed for access to the remote lock control receiver.
This process will require the use of the program switch located on the remote lock control receiver just above the cross car wiring harness connector.
Use the following procedure to erase the remote lock control receiver program memory.
1. Trun the ignition switch to the RUN position.
2. Depress and hold down the program switch on the remote lock control receiver for ten seconds. The receiver will then acknowledge successful erasure by locking and unlocking the power door locks.
After previously programmed transmitters have been deleted from membory the new codes need to be programmed into the remote lock control receiver memory.
Use this procedure.
1. Turn the ignition switch to the RUN position
2. Momentarily depress the prgram switch on the remote lock control receiver. The operator then has ten seconds to program the first transmitter.
3. Operate any button on the first transmitter to program and store the security code for transmitter #1. The remote lock control receiver will then acknowledge successfully programming by locking and unlocking the power door locks.
4. The operator then has ten seconds to program the next transmitter by repeating step 3 for the second transmitter.
5. After two transmitters have been trained, programming of the remote lock control receiver is complete. Wait ten seconds after the second transmitter has been programmed to test the remote lock operation of the transmitters.
Google
Web AF
