What kind of sensors are these? '87 waterneck
deesandvees
01-21-2008, 03:50 PM
http://i121.photobucket.com/albums/o219/ernestmayhand/Caprice%20resto/waterneck.jpg
PeteA216
01-21-2008, 04:46 PM
(L-REAR) ECM Temp Sensor and (R-FRONT) a sort of temperature sensitive vacuum valve, I believe for the canister or PCV... one of the two. It's been a while since I've had either on my car.
deesandvees
01-21-2008, 05:04 PM
I'm ditching the ECM so I guess I'll be picking up a neck with no ports on it then. Just been trying to figure out what all needs to be hooked up to get going on this.
http://i121.photobucket.com/albums/o219/ernestmayhand/Caprice%20resto/011motortrans.jpg
http://i121.photobucket.com/albums/o219/ernestmayhand/Caprice%20resto/031.jpg
j cAT
01-21-2008, 07:35 PM
the left one is engine temp the right is i believe EGR. when engine cold no EGR valve should open . on temperature rise.......vacuum is allowed to open egr......through this valve......
randy78
01-31-2008, 04:57 AM
buy brass water pipe plugs at your local hardware/plumbing store to plug those off
paint it all black
done and cheap and easy
i do this all the time on these
good luck
