Rear Pinion Bearing
SteveCooke101
01-19-2008, 11:57 PM
Due to an M.V.I i was told to replace my rear pinion bearing. i took the driveshaft apart and the rear pinion oil seal off. now i am having difficulty removing the bearing itself. :banghead: Any ideas or suggestions? thanks!
troy1
01-21-2008, 02:18 PM
They usally are a tight fit. Replacing one is a waste of time there are two bearings on the pinion shaft. If that bearing is bad others usally are too.
SteveCooke101
01-23-2008, 09:07 AM
yeah i figured i my as well do both while i have it apart. Do i have to punch them out from the inside of the dif or will they come out through the drive shaft side?
