2001 GMC Jimmy w/Intermittent ABS Light
monk02
01-19-2008, 05:43 PM
I recently had brake work done to my vehicle (eg. rotors, pads, calipers, master cylinder) because the brake pedal would sink to the floor whenever approaching a stop sign. Before coming to a full stop (greater then 10mph), the brakes work normally. However, that didn't fix the problem. What fixed the problem ultimately was the replacement of the valve modulator on the ABS. What has now happened, every other day, the ABS and brake lights go on and stay on until the engine is turned off and then turned on again. The brakes seem to work fine......the shop told me that sometimes with the new modulators, the valves being new have some 'resistance' as it takes time, as they move back and forth to 'work them in'. Does this mean that there might rather be air trapped in the ABS modulator that needs bleeding again ? My understanding is that bleeding the brakes with ABS is a pain and that a person needs a system tool to do the job right. :banghead:
MT-2500
01-19-2008, 07:08 PM
They are feeding you a big bull line hook and sinker.
Better find another repair shop that knows what they are doing and know how to bleed the abs brakes with a abs capable scanner.
If the brake light comes on you have a problem.
First step is to get the abs code and post back code for help on it.
MT
monk02
01-20-2008, 03:58 PM
I admit, the reason did sound flaky. The only other thing to replace would be the control module for the ABS and that's $929 IF there is no air in the system. But I doubt that is the problem......the ABS works just fine.
MT-2500
01-20-2008, 04:34 PM
You need to catch the code when the light is on and go with what the code says.
Good luck
MT
monk02
06-02-2008, 12:07 AM
What model system scanner to buy would be best for my 2001 GMC Jimmy ?
MT-2500
06-02-2008, 10:18 AM
The GM tech 11-111 scanner or a snap on Solus scanner will do Air bags And ABS.
But the price range is 3500 -5000 $ USA dollars.
For a one time dealer it is best to pay a repair shop to scan it.
blazes9395
06-02-2008, 11:33 AM
Like MT mentioned, get it scanned. If the lights both go on (ABS & BRAKE) and reset after, I am willing to bet its most likley a loose or shorting ABS line from one of the wheel sensors. If it was damaged during the brake job, or not routed properly after the brake job, it will cause a short and both lights will come on like that.
duke350
06-02-2008, 12:51 PM
Actron also has a new ABS scanner. I know nothing about it, I just saw it sitting on the shelf at a local parts house. Its priced at about $300. I have no exp. with it, I just saw it there.
GMC3peat
08-22-2008, 09:15 AM
Hello Folks, great forum!!...1st time user...for a novice I find info. 'bang on'...my 2001 Jimmy is having the same problem...either starts out with no lights & after a few minutes ABS & parking light come on..or...starts with ABS & parking light on...any inexpensive way to test & repair this??
MT-2500
08-22-2008, 09:31 AM
Welcome to AF.
Read threw this thread and it explains how to test for a ABS light.
On your problem it is best to start a New Thread.
Saves on highjacking a old post that was started by someone else.
Hit the New Thread button and give all information and someone will help you.
MT
GMC3peat
08-22-2008, 09:51 AM
still looking for that New Thread button...in the meanwhile...mechanic tells me it was a C0265 code that he cleared a few times & re-appears...
MT-2500
08-22-2008, 09:59 AM
Left side and up a little at the top of post.
MT
MT-2500
08-22-2008, 10:08 AM
Code is for wiring circuit problem that can lead several directions.
This is a code where you need to go threw the repair flow chart for the code.
Does you mechanic have any repair information or what did he say to do on it?
Are you going to DIY it or let him fix it?
MT
