Drip Stick Tubecitydragon 01-18-2008, 07:54 PM I noticed my dip stick tube is wiggly it never was loose before...is there a way to tighten it. Please no smart-a$$ replies. LOL dwendt1978 01-19-2008, 10:26 AM On 95% of all dipsticks, the tube is usually pressed into the engine block, then has a bracket on it that is bolted to the engine somewhere. Check to see if the bolt is loose and tighten it. If you have to tap it back down into the engine, do it very lightly. citydragon 01-19-2008, 02:32 PM On 95% of all dipsticks, the tube is usually pressed into the engine block, then has a bracket on it that is bolted to the engine somewhere. Check to see if the bolt is loose and tighten it. If you have to tap it back down into the engine, do it very lightly. Done...thanks! vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
