'41 Plymouth....need help.Donzie 01-15-2008, 01:04 AM I just picked up this '41 Business coupe. As you can see, the hood was partially open. When it was delivered they had closed the hood. Now I can't get it open. It has an inside hood release but I can't get it to budge. Any suggestions? Also, the car hasn't run in 3 years, any suggestions as to what I should do to try and get it running?. I thought I would see if it will roll over to be sure it isn't froze up. If it does I was going to put in new plugs and spray the carb with cleaner before I tried to fire it. Am I on the right track? The trunk lid is pretty dented up. It's not rusted out just some big dents. Any idea what a good replacement would cost? I'm wondering it it's worth trying to fix it. Lastly (for now), is the wheel bolt pattern the same as Fords? Thanks for any help you can offer. http://www.jalopyjournal.com/forum/attachment.php?attachmentid=397728&d=1199682518 http://www.jalopyjournal.com/forum/attachment.php?attachmentid=397733&d=1199682518 vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
