abs light ondrivena98 01-10-2008, 07:49 AM the abs light is on in my wifes malibu and the right front wheel bearing needs to be replaced asap. could the bearing be causing the light to come on? (there both 1 unit). 16th hippy 01-10-2008, 07:56 AM yes, the hub(bearing) houses the sensor. if it is loose, or even just failing, it can damage sensor. if light is still on after road test, the pigtail might need to be replaced. seen this on some malibus. let us know how it goes! drivena98 01-10-2008, 09:22 AM 16th, thanks for the note. i will replace the bearing and let you know how it goes. 16th hippy 01-11-2008, 03:11 AM cool beans, hope all goes well! drivena98 01-11-2008, 04:58 PM 16th hippy, i replaced the bearing. no more noise and no more abs light. thanks again for your input. all is good again! 16th hippy 01-11-2008, 06:05 PM no prob, glad it's fixed! vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
