terrible miss/backfire
Google
Web AF
blazinman08
01-07-2008, 08:04 PM
whe i am driving it backfires through the throttle body and loses power i cannot figure this out could this just be fouled out spark plugs
old_master
01-07-2008, 08:15 PM
Year, make, model, engine, 8th character of VIN, what's been done to the vehicle as far as repairs, SES light on? What DTC's are stored? We need more information to help you.
blazinman08
01-07-2008, 09:03 PM
it is a 89 s10 blazer 4wd 4.3 L fuel injected replaced fuel filter,coil,spark plugs and wires, distrubtor cap and rotor
blazinman08
01-08-2008, 01:48 PM
can some one please help
old_master
01-08-2008, 06:49 PM
Induction, (backfire through the intake), can be caused by incorrect valve timing, incorrect ignition timing, excessively lean fuel mixture, or incorrect secondary ignition wiring. Check the easy stuff first: ignition timing, plug wires correctly in the distributor cap, (firing order), and fuel pressure.
blazinman08
01-10-2008, 12:55 PM
i checked the firing order that is correct now how do you check ignition timing
old_master
01-10-2008, 05:12 PM
Behind the carpet, under the glove box, next to the firewall, there is a single wire with a connector, unplug it and check ignition timing with a timing light. Sticker under the hood should give the spec.
Google
Web AF
