Our Community is 705,000 Strong. Join Us.
04 aveo
hawkifootball
12-31-2007, 11:32 PM
Can some one tell me how to adjust the headlights on a 04 aveo they aim to low.
michaelodonnell123
01-03-2008, 05:09 PM
To check if you do need to adjust your car’s headlights, park your car first somewhere where the ground is flat. Make sure that the front of your car is facing a flat surface – a wall, a fence, or a garage door, perhaps. And then, turn the headlights on. You would know that they are correctly mounted if they are straightly even.
If you find that they do need a little tinkering and adjusting, you can lower or raise the beams by loosening or tightening the adjustment screws of the headlights with your screwdriver. The adjustment screws can be found usually on the side and the bottom of the headlights.
