class II hitch photo
463
12-29-2007, 11:36 AM
class II hitch photo & 4 pole trailer electrical plug on my 02 silhouette http://i242.photobucket.com/albums/f...s/vanxm010.jpg (http://i242.photobucket.com/albums/ff306/463_photos/vanxm010.jpg) (http://i242.photobucket.com/albums/ff306/463_photos/vanxm010.jpghttp://)
larrysbk
01-01-2008, 09:25 PM
Where did you buy the hitch and electric? Did you install it yourself?
463
01-02-2008, 10:28 AM
i picked up a used hidden hitch from the GM dealer part # HID90103 ($ 106 )and 6 grade #8 bolts/nuts and washers. the 02 olds has the trailer tow pack from the factory( rpo# v08-hd rad,v92-wire provisions,kc4-eng oil cool,fe4-ride pak,) and all the extra toys. the install with my sons help was apx 1.5 hrs. the van has the air ride and this is where the extra time is spent with the air pump r and r to get the hitch up and in. the drilling in the frame ( if you can call that stamped tin a frame) is to easy and to light in my books to pull a 3000 lb trailer. the wire kit came with the van and i added a hopkins wire adapter # 46155 also from the gm dealer $28 (from the vans 5 wire to 4 wire flat plug. gm #12144979 on the wire diagram sheet) . Up by the air pump there is a blank plug that i removed and plugged in the wire harnes and feed it over to the hitch. there is a orange wire that had to be sealed off as it's a 12 dc live wire not used in this install. the hoppy wire kit has a 4 plug adaptor wire to plug in to the plug in on top or the hitch in my photo to reach to the trailer wire. this works well in that it keeps the plug clean and free of road salt and dirt. Greg.A was a help with this and here is some links http://www.my-chevy-venture.com/trailer- http://www.automotiveforums.com/vbulletin/showthread.php?t=581090wiring.html and a link from a saturn form http://www.saturnfans.com/forums/showthread.php?t=86775 http://www.truckstuffusa.com/powertaillightconvertersbyhoppy.html
