Question 4 The Honda Techs?1990civic 02-18-2003, 01:01 AM i recently rebuilt my engine, and i tried to start the engine, and the engine turns over, but there is no spark at all. i have taken the dizzy and tested it on a different car, and it worked fine. what are the next steps i should take to correct this problem?? ev0lution7 02-18-2003, 04:17 AM this is a stupid question but did ya make sure the GROUNDS to the head and to the tranny are ON tite?? and what about the ECU? maybe some of the CARS wiring is F'd up?? check all eletrical connections between ECU and distro turbcivic 02-18-2003, 02:50 PM Test igntion coil, ignitor, and igntion switch. If any test bad, replace. Try checking to make sure all wires are plugged in correctlly and that the ecu works properly. 1990civic 02-18-2003, 11:27 PM what ground do you mean? (the one on the valve cover), Test igntion coil, ignitor, and igntion switch were all tested, and they work fine. wouldnt the ecu flash is the wire were hooked up wrong?? thanks 4 tha help turbcivic 02-19-2003, 06:56 AM The ecu would read a signal from the igntior and that is what would throw a code 15, igntion output signal. The igntor still thinks the igntion coil works and the ecu wouldn't know so no code. What tests didi you do? What does it sound like when you turn the key. Check the main relay. 1990civic 02-19-2003, 07:17 AM i swapped all of those parts to a diff civic, and they worked fine. is the main relay in the fuse box? turbcivic 02-19-2003, 07:40 AM No, it is under the dashboard on the drivers side all the way down. I will see if a i can find a picture of its location. 1990civic 02-19-2003, 09:46 AM how would i check the main relay? turbcivic 02-19-2003, 10:41 AM It is hard for me to explain but here is a website. http://techauto.tripod.com/gifcivic.htm I'm a better show them what to do then tell them what do person. 1990civic 02-20-2003, 12:45 AM if the main relay was not working would the dash light up? if not what else wouldnt work if the main relay was broken? vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
