1998 Tahoe Keyless Entry Programming
Google
Web AF
Raistmaj
02-16-2003, 12:22 PM
Does this procedure also work for a 98 tahoe? I tried it with no luck so far.
Thanks
Shortbus
02-17-2003, 10:27 AM
Thanks
Nope they are different.
Here is the method for a 1998
Transmitter Programming
If they key is in the ON position during the programming procedure, the horn chirp will be disabled, if the key is in the OFF position, the horn chirp will be enabled. The horn will chirp when the lock button is pressed two times.
When reprogramming the remote control door lock reciever, All transmitters must be programmed at this time in order for the transmitters to operate the vehicle. Transmitters not programed at this time will not work and the procedure will have to be redone with all the transmitters.
Ground pin 4 to pin 8 of the data link connector (DLC). The receiver will respond by locking and unlocking the doors, and activating the liftgate window release (if equipped) within 2 seconds.
Press and hold the LOCK and UNLOCK buttons simultaneously on the first transmitter to be programmed until the locks cycle (approximately 10 seconds).
Repeat step 2 for up to four total transmitters to be programmed (if available). The receiver will respond by locking and unlocking the doors and activating the liftgate window release (if equipped) within 2 seconds.
Remove the ground applied to the DLC.
Lock and unlock the doors in order to verify the transmitter operation.
Activate the rear window release in order to verify the transmitter operation.
© Copyright General Motors Corporation. All Rights Reserved.
Raistmaj
02-17-2003, 02:06 PM
Do you know the location of the DLC?
Thanks
Shortbus
02-17-2003, 02:15 PM
Under LH of IP, LH of Steering Column, mounted to bottom of Knee Bolster
http://files.automotiveforums.com/uploads/400363DATALINK.jpg
Shortbus
02-17-2003, 02:20 PM
This will also come in handy when grounding the terminals
Connector Part Information
12110250
16 Way Metri-pack 150 Series (BLK)
Pin
Wire Color
Circuit No.
Function
1
Not Used
2
PPL
1807
Serial Data Signal-Class B
3
Not Used
4
BLK
150
Ground
5
BLK/WHT
451
VCM Ground
6-7
Not Used
8
BLK/WHT
1455
Keyless Entry Program Enable Signal
9
TAN
800
SIR Serial Data
10-11
Not Used
12
TAN/WHT
799
Diagnostic Signal (ABS)/(15,000 GVW Only)
13
ORN
1568
Diagnostic Signal-Transfer Case Control Module
14
GRN DK
835
Diagnostic Signal-Entertainment and Comfort
15
Not Used
16
ORN
1840
Fuse Output - Battery - Type III Fuse
http://files.automotiveforums.com/uploads/594393CONNECTOR.jpg
Raistmaj
02-17-2003, 05:59 PM
It worked like a charm, thanks for the help. I have had a new remote for months now and was not able to find the information anywhere.
THANKS!
Shortbus
02-17-2003, 06:45 PM
Your welcome.
I think I will split this so others can find it for their 98 and label it Keyless Programming for 98 Tahoe.
Thank you for letting us know how it went.:)
three6ohchris
03-14-2003, 06:53 PM
does this work for the 96 as well?
mtbikeracer
10-09-2005, 04:01 PM
Thanks
This procedure also works for 1999 Tahoe keyless entry programming. Thanks for the help, it sure beats paying for the instructions.
eriojas
12-08-2005, 07:45 PM
2002 suburban, changed battery on remote, did the on off procedure with the unlock button and buttons close and open, press lock and unlock on the remote and buttons open and close, after that the remote still doesnt work, any ideas
thanks
Onblsht
12-14-2005, 11:58 PM
Do you have the correct remote for the 02?
If it's the 3 button unit, its the KOBLEAR1XT / 15042968 remote which is not interchangeable with the older KOBUT1BT / 15732803 unit.
eriojas
12-15-2005, 09:26 AM
its the original from new, worked perfectly until abou two weeks ago it just stopped working, thought it was the battery and changed for a new one, and still no luck, thanks
Google
Web AF
