rims
beastman
02-03-2003, 02:35 PM
can i paint my stock rims white? If so what paint and procedure would i use? Thanks
Pikachoo
02-04-2003, 07:55 AM
Just use regular old spray paint of a good quality, and some clear coat also.
Get rid of the clear coat that was originally on the wheels. Start with 80 grit paper to get the clear coat broken up then, use 120 grit then 400 grit sandpaper. Take your time.
You'll probably want to clean them with soap and water after you sand them. Next spray three or four light coats. Don't use too much paint or you will get drips or ripples in the paint.
Then break out the clear coat and spray on three or four coats. Let dry.
:smoka: :smoka:
bowtiebandit
02-04-2003, 09:42 AM
This is a bulletin from General Motors on aluminum wheels
MATERIAL REQUIRED:
SYSTEM 1: DUPONT PRODUCTS 3939-S CLEANING SOLVENT 615/616 ETCHING PRIMER URO 5000 PRIMER SURFACER IMRON 6000 BASECOAT 3440-S IMRON CLEAR
SYSTEM 2: PPG PRODUCTS DX533 ALUMINUM CLEANER DX503 ALUMINUM CONDITIONER DP EPOXY PRIMER DELTRON BASECOAT (DBC) CONCEPT 2001 CLEAR ACRYLIC URETHANE
SYSTEM 3: SPIES HECKER PERMAHYD SILICONE REMOVER 7090 PERMAHYD 1:1 PRIMER 4070 PERMAHYD 2:1 SURFACER 5080 PERMAHYD BASE COAT SERIES 280/285 PERMAHYD H.S. CLEARCOAT 8060
COLOR SELECTION
IF THE WHEELS BEING PAINTED WERE PREVIOUSLY CLEARCOATED ALUMINUM, WE WOULD RECOMMEND USING CORSICAN SILVER WAEQ9283 FOR A FINE "ALUMINUM- LIKE" LOOK OR SPARKLE SILVER WA9967 FOR A VERY BRIGHT LOOK. AS AN OPTION TO THE CUSTOMER, YOU MAY ALSO USE BODY COLOR. FOR COLOR SELECTION AND VERIFICATION, REFER TO YOUR PAINT MANUFACTURER'S COLOR BOOK. ON WHEELS THAT WERE PREVIOUS CLEARCOATED ALUMINUM IT IS RECOMMENDED THAT ALL FOUR WHEELS BE REFINISHED TO MAINTAIN COLOR UNIFORMITY. FOR COLOR UNIFORMITY IT IS RECOMMENDED THAT ALL FOUR WHEELS, AND THEIR CENTER CAPS BE REFINISHED.
IMPORTANT: THE PRODUCTS LISTED MUST BE USED AS A SYSTEM. DO NOT MIX OTHER MANUFACTURERS' PRODUCT LINES WITH THE REQUIRED MATERIALS. PRODUCTS LISTED IN THIS BULLETIN HAVE SHOWN THE REQUIRED REPAIR DURABILITY, AND CURRENTLY ARE THE ONLY PAINT SYSTEMS THAT MEET GM SPECIFICATION 4350M-A336.
PROCEDURES
1. REMOVE WHEELS FROM VEHICLE. TIRES MAY REMAIN MOUNTED ON WHEELS.
2. REMOVE BALANCE WEIGHTS AND MARK THEIR LOCATION ON TIRE.
3. WIPE EXCESS GREASE, ETC. FROM WHEELS WITH WAX AND GREASE REMOVER.
4. HAVE WHEELS PLASTIC MEDIA BLASTED TO REMOVE CLEARCOAT. FOR FURTHER INFORMATION ON MEDIA BLASTING IN YOUR AREA, CALL US TECHNOLOGIES INC., CONTACT DAVE ROSENBURG AT 1-800-634-9185.
CAUTION:
IT IS MANDATORY THAT ADEQUATE RESPIRATORY PROTECTION BE WORN. EXAMPLES OF SUCH PROTECTION ARE: AIR LINE RESPIRATORS WITH FULL HOOD OR HALF MASK. IF NOT AVAILABLE, USE A VAPOR/PARTICULATE RESPIRATOR THAT RESPIRATOR MANUFACTURER RECOMMENDS AS EFFECTIVE FOR ISOCYANIATE VAPOR AND MISTS (UNLESS LOCAL REGULATIONS PREVAIL).
5. PAINTING PROCESS
A. REFER TO ATTACHMENTS 1-3 FOR EACH SYSTEM'S INDIVIDUAL FORMULA AND PROCESS.
B. AFTER FOLLOWING THE SPECIFIC SYSTEM'S INDIVIDUAL FORMULA AND PROCESS, FOLLOW THESE STEPS:
6. UNMASK WHEELS.
7. CLEAN ALL WHEEL MOUNTING SURFACE OF ANY CORROSION, OVERSPRAY, OR DIRT.
8. INSTALL NEW COATED BALANCE WEIGHTS, AT MARKED LOCATIONS.
9. REPLACE WHEELS ON VEHICLE.
10. **USE A TORQUE STICK ON AN IMPACT WRENCH, OR A TORQUE WRENCH TO CONSISTENTLY AND UNIFORMLY FASTEN THE WHEEL TO THE SPECIFIED TORQUE FOR THE VEHICLE. THE STAR PATTERN MUST BE FOLLOWED.**
IMPORTANT: TORQUE STICKS MUST BE USED ANY TIME AN IMPACT WRENCH IS USED TO TIGHTEN WHEEL NUTS.
ATTACHMENT 1 PAINTING PROCESS SYSTEM: DUPONT PRODUCTS PAINT COLOR INFORMATION: CORSICAN SILVER WA EQ9283 DUPONT #C9143 SPARKLE SILVER WA9967; DUPONT #C9339
1. WIPE WHEEL WITH CLEANING SOLVENT: 3939-S, 3949-S OR3900-S.
2. MASK OFF TIRES.
IMPORTANT: 3. MASK OFF ALL WHEEL MOUNTING SURFACES AND WHEEL MOUNT SURFACES.
4. APPLY TWO COATS OF 615/616-S ETCHING PRIMER TO WHEEL ALLOWING 10 MINUTES FLASH BETWEEN COATS. ALLOW TO DRY FOR 30 MINUTES BEFORE APPLYING PRIMER COAT.
5. APPLY URO 5000 PRIMER 1220/193-S + ACCELERATOR 389-S USING TWO COATS AT 65-70 PSI AT THE GUN. ALLOW 12-15 MINUTES BETWEEN COATS. FORCE BAKE 30 MINUTES AT 140 DEGREES F (60 C).
6. SCUFF SAND USING GREEN SCOTCH-BRITE PAD.
7. SOLVENT WIPE BEFORE TOP COATING.
8. APPLY IMRON 6000 BASE COAT TO WHEEL. 2-3 COATS TO HIDING AT 60-70 PSI ALLOWING TO FLASH BETWEEN COATS. BASE COAT NEEDS TO DRY 20-30 MINUTES BEFORE CLEARCOAT IS APPLIED.
9. APPLY 3440-S CLEARCOAT TO WHEEL USING TWO COATS AT 60-70 PSI. FLASH 10-15 MINUTES BETWEEN COATS. 389-S CAN BE USED IN BASECOAT AND CLEARCOAT TO GIVE FASTER SET UP TIMES.
10. ALLOW OVERNIGHT DRY BEFORE REASSEMBLE. CAN BE BAKED FOR 30 MINUTES AT 140 DEGREES F (60 C).
ATTACHMENT 2
PAINTING PROCESS PPG SYSTEM PAINT COLOR INFORMATION: CORSICAN SILVER WAEQ9283; PPG #DBC-3531 SPARKLE SILVER WA9967; PPG #35367
1. WASH ENTIRE WHEEL WITH ALUMINUM CLEANER DX533, MIX 1:3 WITH WATER. ALLOW TO REACT 2-3 MINUTES AND RINSE THOROUGHLY.
2. WASH ENTIRE WHEEL WITH ALUMINUM CONDITIONER DX503 STRAIGHT FROM THE CONTAINER. ALLOW TO REACT 2-3 MINUTES UNTIL PALE GOLD OR TAN COLOR DEVELOPS. RINSE THOROUGHLY AND DRY.
3. MASK OFF TIRES.
IMPORTANT: 4. MASK OFF ALL WHEEL NUT MOUNTING SURFACES AND WHEEL MOUNTING SURFACES.
5. APPLY 1-2 COATS OF DP PRIMER AND ALLOW TO FLASH FOR 15-20 MINUTES.
6. APPLY 2-3 COATS OF DELTRON BASECOAT (DBC) AND ALLOW TO FLASH 20 MINUTES AFTER THE FINAL COAT.
7. APPLY TWO (2) WET COATS OF CONCEPT 2001 ACRYLIC URETHANE.
8. FLASH 20 MINUTES AND BAKE 140 DEGREES F (60 C) FOR 30 MINUTES.
FOR MORE INFORMATION CONTACT YOUR PPG JOBBER.
ATTACHMENT 3 PAINTING PROCESS SPIES HECKER SYSTEM PAINT COLOR INFORMATION: CORSICAN SILVER AWEQ9283; SH-72913 SPARKLE SILVER WA9967; SH-71912
1. CLEAN WITH PERMAHYD SILICONE REMOVER 7090.
2. MASK OFF TIRES.
IMPORTANT: 3. MASK OFF ALL WHEEL NUT MOUNTING SURFACES AND WHEEL MOUNTING SURFACES.
4. APPLY 1-1/2 COATS OF PERMAHYD 1:1 PRIMER 4070. MIX 1:1 WITH PERMAHYD HARDENER 3070 AS PER TDS.
5. ALLOW TO FLASH FOR 30 MINUTES.
6. APPLY TWO (2) COATS OF PERMAHYD 2:1 SURFACER 5080. MIX 2:1 WITH PERMAHYD HARDENER 3071 AS PER TDS.
7. BAKE FOR 60 MINUTES AT 140 DEGREES F (60 C) OR ALLOW TO FLASH FOR 3 HOURS AT 68 DEGREES F (20 C).
8. APPLY PERMAHYD BASE COAT SERIES 280/285 AS PER TDS.
9. ALLOW TO FLASH 10 TO 15 MINUTES.
10. APPLY 1 TO 2 COATS OF PERMACRON HIGH SOLID CLEAR COAT 8060 AS PER TDS.
11. ALLOW TO FLASH 10 MINUTES. THEN BAKE AT 140 DEGREES F (60 C) FOR 40 MINUTES
Pikachoo
02-04-2003, 10:43 AM
wife: "Mark... why in the hell is there a car tire in the oven?!?!" :bloated:
:D :D :D
beastman
02-04-2003, 02:50 PM
Thanks guys. I really appreciate it. Thanks for the detailed instructions.
