'92 golf hard start/no run
Google
Web AF
MetroBrad
01-31-2003, 02:57 PM
My girlfriends golf is very hard to start and will not idle.
I have checked it out and I have narrowed it down but still cannot figure it out. I have established that there is fuel pressure, spark, the idle air bypass is ok, ignition module is ok, and there is sufficient air flow. While
testing the input to the coil I noticed a slightly erratic spark condition right before the car dies. By trial and error i discovered it wasnt the ignition module. I think it is the stator in the distributor but I'm not sure.
PLEASE HELP.
B
Deakins
01-31-2003, 03:37 PM
8v or 16v?
Have you checked the hall sensor?
MetroBrad
01-31-2003, 03:44 PM
We did check it with a test light, it seemed ok but i also think that could
be the problem. BUT its expensive and i cannot return it if that is not the problem. Do you know of any better way to test it?
Also we don't know where to check for trouble codes>
its an 8v
B
Deakins
01-31-2003, 04:11 PM
Besides a voltmeter, no.
It could be the knock sensor, and even the ecu.
I don't really have any experience with Digifant engines. :(
You could get the fault codes with a VAG-COM (http://www.ross-tech.com/vag-com/), or at a dealer.
MetroBrad
01-31-2003, 06:33 PM
all the guys at my shop agree with you that it could be the hall sendor.
I just orderd one adn hopefully it fixes the problem.
Thank you for your input.
B
Deakins
01-31-2003, 06:37 PM
np.
But wouldn't it be cheaper to find a used distributor at a JY?
MetroBrad
02-01-2003, 01:39 PM
it would be cheaper at a wrecker but they are non returnable.
from the parts store I can return it if the problem isnt fixed.
B
MetroBrad
02-07-2003, 02:44 PM
So I tried replacing the hall sensor, it didnt work
So I then checked the valve timing. It turns out that
her timing belt had skipped a tooth. I replaced the timing belt and it fired right up.
all that trouble and it was the timing belt.
B
px3
03-18-2003, 06:45 PM
B
Same thing happened to me when my VR6 chain skipped.
Google
Web AF
