VW Golf IV from hellSpeedfreak17 10-08-2001, 09:40 AM check out this VW Golf RSI from hell It all started in 1998 with an empty Golf IV body in the workshop. The brand new body has now been completely stripped with a new floor, new front and rear subframes and a roll cage. Everything has been built from chrome-molybden pipes. The wide kit-car flares from VW Motorsport in Hannover provide enough space for big rims and tyres. Front subframe and suspension Rear subframe and suspension The rear subframe and suspension is a mix of Audi RS2 and Sport Quattro with titanium swaybars and magnesium suspension struts. The front subframe is custom built, also with titanium swaybars and magnesium suspension struts. The exhaust is built from 4.5" stainless steel pipes all the way from the turbo and back with a single muffler under the car. The transmission stems from an Audi IMSA car with a custom built final drive. Recaro carbon fibre sport seats, 6-point harness Carbon fibre instrument panel and door trims To further reduce weight, many of the stock parts have been replaced by correspondning parts made from carbon fibre. For example, the instrument panel, door trims, hood and bumpers have all been replaced by carbon fibre dittos. The stock seats have been removed in favor of Recaro carbon fibre sport seats with 6-point harness belts. All windows are made from lexan plastic. 2.1 litre inline five cylinder turbo engine with a power range of about 600-900 hp The stock 1.8 litre engine has been replaced by an inline five cylinder 2.1 litre Audi turbo engine with two large intercoolers. The engine develops about 600-900 hp depending on the choice of turbo and setup. To make room for the larger engine, the inner fenders had to be replaced by chrome-molybden pipes. Water and oil cooler moved to the back Alcon brakes, 375 mm rotors, 10x19" wheels The larger engine did not leave any space for water or oil coolers in the front of the car so these had to be moved to the back with an air intake in the roof. The car is equipped with Alcon brakes with 375 mm front rotors and 355 mm rear rotors. Thanks to the wider kit-car flares, it is possible to use 10x19" rims with Bridgestone 265/30-19 or 12x20" rims with Bridgestone 285/30-20. The overall weight of the car is about 900 kg. http://www.audituning.com/english/default.html:smoker2: :smoker2: :smoker2: :smoker2: :smoker2: :cool: :cool: :cool: Speedfreak17 10-08-2001, 09:46 AM Here is some proof Max. power engine 527.6 kW @ 5.780 r/min Max. power at wheels 432.2 kW @ 5.780 r/min Max. torque 928.6 Nm @ 5.250 r/min Note! Impossible to attain traction above 5800 r/min during the test. Maximum power is between 7800-8200 r/min Dyno test performed by Flissundet Motorservice This Golf is a real badass. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
