Clarion deck and subs.. Installation!frogg 10-04-2001, 08:47 PM Ok, this is the deal. I have a Clarion DRX9675z deck. Im also installing a Rockford Fosgate Punch 1000d amp and 2 Infinity Perfect 12.1's. If possible, I would like to just use the stock speakers (Bose). Oh ya, the head unit would be acting as the amp for the speakers. What exactly do I need for this to work? I need a wiring harness and antenna adapter? Anything else? Please help guys! Edit: Oh ya and I have the double DIN stock system which the deck is made by Clarion (P11 right?) frogg 10-05-2001, 09:38 PM Cmon guys, someones gotta know what I need.. pche059 10-06-2001, 04:39 PM hey man it should be pretty straight forward... get a volt meter....work out your wires that give you 1) 12V constant 2) 12V ignition on 3) 12V remote (can't remember if you need it for head unit or not) :p 4) 12V illumination (lights) for your earth just earth it directly to the chasis make sure the antenna has the right adaptor....if not just cut it and put a new adaptor on. btw awesome amp you got there :) 4 your amp... depends on how you wanna do it....are you gonna run caps? or upgrading your system with another amp (to run your fronts)? which i think you prolly will :) you will need to run 4G wire from your battery ..then either an inline fuse holder or a power distrubition box will do.... put the right fuse in :) 12v remote wire from the head unit to the amp ...(amp will only be turned on when the headunit is on) 4G wire earth from your amp to the chasis...as short as possible... RCAs from your headunit to your amp(sub channel out) just hook up the speakers to the headunit...make sure they are in phase :) and your subs to the amp....and way you go..... oh...are your subs in a box yet? frogg 10-06-2001, 05:21 PM Hey thx for replying. I ordered a wiring harness for the receiver because I didnt really want to cut the wires. Not running caps right now.. also not running fronts with a seperate amp but will later. I have a custom box that I made that I put the subs in.. still need to carpet it but it's fine for now. pche059 10-06-2001, 10:05 PM that's all good make sure you run good cables for your system,... good installation makes the difference esp for good system like yours.... hehe also make sure your battery is handling the current drawn....altho the RF class Ds are meant to be fair efficient as well for your subs.... make sure the box is of the right size.... is a sealed or ported? *i perfer sealed box* :p anyone keep my updated with your system aye.... would like to know how those perfects handle with so much clean power :) vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
