shackles
View Full Version : shackles shackles Aythya 01-13-2003, 12:27 AM No where near the stress yall are putting them under any recommendations? Thanks in advance! Aythya 01-13-2003, 12:28 AM sorry meant to post a reply.......... Schludwiller 01-13-2003, 12:59 AM If you can afford it, get Add-A-Leafs instead. Spencerlowracing.com has the best set out there so far (3 leaf set). Of course your rear will be high, so you'll need to lift the front some with the torsion bars. Schackles without better leafs will just make them wear prematurely. OffroadX 01-13-2003, 11:03 AM Keep in mind you'll need new shocks to deal with the longer distance between axle and frame, or use the Darlington UB Skidderz to raise the lower mount of the shocks (my plan). Brent Related Links Participate in thousands of discussions at AutomotiveForums.com! Registration is absolutely free. |
