MAF sensor voltages - Problem? (Post attempt #2)rdavenpo 01-03-2003, 11:29 PM My 93 NA lacks power and stumbles (lightly) above 2500 RPM's, especially when it is cold outside and the engine is cold. I checked the MAF sensor voltages... Voltage at idle was about 1.2 (0.8 - 1.5 is normal). Voltage at 2000 RPM's was about 1.55 (1.4 - 1.8 is normal). Voltage with ignition on and engine off was 0.43. Manual says about 0.8 volts is normal, so a bit off here. Any idea as to whether the low voltage indicates a problem? Other Checks Performed -Changed spark plugs (Denso double platinum, properly gapped, normal heat range) - No difference -Changed air filters - No difference -Changed fuel filter - No difference -PCV valves OK (good vacuum at valves, internals move freely, no sludge) -Pressurized intake to check for leaks -Replaced oxygen sensors & checked with ECU (rich-lean switch every second or so at 2000 RPM's) -No trouble codes in ECU (checked multiple times over several hundred miles) -Throttle bodies OK (cleaned 1500 miles ago, still very clean) -Compression OK (~195 PSI with 8 PSI difference between cylinders) -Cleaned most sensor and actuator connectors using electronic parts cleaner -Checked fuel pressure (idle = 36, FPR disconnected = 45, light accel = 42-43, heavy accel = 45) -Holds fuel pressure OK (No drop after 10 minutes) -Vacuum OK (idle = 19 in, 2000 and 2500 RPM's = 21 inches, 3000 RPM's = 20 inches) -Removed purge line from carbon cannister and plugged - No difference -Coil pack resistances OK -TPS OK (Resistance and voltage closed and wide open at spec, no dead spots during slow opening) -Closed throttle position switch OK -Coolant temperature sensor resistance OK (cold, warm, hot) -Fuel temperature sensor resistance OK (cold, warm, hot) -Detonation sensor resistance OK -Fuel injector resistances OK Anything else I should check? jlc 01-31-2003, 08:36 PM i have this same problem, if you have fixed this issue PLEASE email me at jamminjman2002@yahoo.com thank you Gradyman25 02-03-2003, 06:40 PM sounds to me like you've already checked everything, i have the same problem and have checked some of the same things you have, but nothing ever seems to work, aparently this problem happens often in the N/A Z's and none seems to have an answere for the problem, so who knows, if you do ever find out what it was please post so we all can know thanks vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
