99 Silverado Oil Change Message
Google
Web AF
chevy9t9
12-22-2002, 12:48 PM
How do you reset the Oil Change message center. The truck did not have an owners manual so I do not know how to reset it.
Shortbus
01-03-2003, 08:43 AM
Oil Life Monitor - Resetting
Description
The engine oil life monitor will indicate when to change the engine oil - usually between 5,000 km (3,000 miles) and 12,500 km (7,500 miles) since the last oil change. Under severe conditions, the CHANGE OIL SOON light may be displayed before 5,000 km (3,000 miles). The vehicle must not be driven more than 12,500 km (7,500 miles) or 12 months without an oil change.
The engine oil life monitor will not detect dust in the oil. If the vehicle is driven in a dusty area, be sure to change the oil every 5,000 km (3,000 miles) or sooner if the CHANGE OIL SOON light is displayed.
Reset the oil life monitor when the oil has been changed, use the following procedure.
Turn the ignition key to the RUN position.
Fully push and release the accelerator pedal 3 times within 5 seconds. If the CHANGE OIL SOON light flashes 2 times, the system is reset. However if the light comes on and stays on for 5 seconds, the system did not reset. Repeat the he procedure if the system does not reset.
Google
Web AF
