no drl, no low beams, ticking noise fuse box
regina92701
12-17-2007, 06:50 PM
i have no daytime running lights, no low beams only high all other lights and accesories work. replaced fuses, drl relay and multifunction switch. there is a ticking noise coming from the area of the fuse box on the left side of my dash when i start the car and put it in gear, it goes away after 10- 15 seconds and my service light is on. after i replaced the multifunction switch the ticking noise and service light went out but appeared the next day. any suggestions would be greatly appreciated
rpw519
12-17-2007, 08:33 PM
You have a broken wire or wires in the front harness, had exact same problem and found about 5 breaks in the harness, check under intake and where harness feeds between washer fluid/ main air induction. You will find it just takes a bit of time to locate.
regina92701
12-18-2007, 04:33 PM
thanks i will have to check that out i want to try whatever i can before taking it to the dealer
