Windshield sprayers?? 97 Camrydannyv23 12-13-2007, 04:20 PM Hi everyone, today I go to clean my windshield and pull back on the handle and to my surprise nothing comes out. I then go and buy windshield washer fluid and fill up the tank and find that it was half way full. So my conclusion now obviously is that somehow some motor has gone out. Does anyone know where I should start my troubleshooting? And for anyone wondering, I live in Los Angeles, no fear of the lines being frozen or anything. I last used it about 3 or 4 days ago and they worked fine then. I didn't have any indication of problems until today when I went to go use them. The wipers still work fine but nothing comes out of the little sprayer things. Thanks for all your help. inafogg 12-13-2007, 05:28 PM hello first i'd check to see if we have a clogged hose.when you try the washer do u hear the pump running??if u do then look for a clogged line.if u dont then suspect the pump/connections.not sure where its located but ck in washer fliud bottle good luck somick 12-13-2007, 06:19 PM It could be a simple matter of a blown fuse. Like inafogg said listen for the running motor. Sam dannyv23 12-14-2007, 04:26 AM Ah, I didn't think about a fuse. Anyone know which fuse runs that motor? DFBonnett 12-14-2007, 10:39 AM Ah, I didn't think about a fuse. Anyone know which fuse runs that motor? www.camrymanuals.com vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
