9-3 Turbo: Removing the harmonic balancer
hakachukai
11-15-2007, 02:42 AM
How do I do it with out pulling the engine? I have an impact wrench, do I really need that special Saab pully holding wrench?
Do I need a special puller to pull it off, or can I just use a regular harmonic balancer puller? Can I heat it with a torch and get it off that way (with out damaging it)?
It has a bad oil seal behind the harmonic balancer, so I have to change it :banghead:
Took me quite a while to even figure out where that massive oil leak was comming from!
If I need to, I was thinking about jacking up one side of the engine so that it would lower the other side just enough for the harmonic balancer to clear the chassis.
I can even dismantle the steering knuckle if I have to. I can pretty much do anything except actually pull the engine.
Any thoughts?
hakachukai
11-16-2007, 01:26 PM
Well that was a LOT easier then I thought!
Remove the serpintine belt
Jack the car up
Remove the front passenger tire
Remove the plastic cover
Remove the Giant bolt in the harmonic balancer using a impact wrench
And surprisingly... the harmonic balancer come right off with your hands.
