How to paint your car for $75.00 - No kidding
Google
Web AF
Styluss
11-12-2007, 04:48 PM
I recently just finished painting my car myself, at home, in my driveway.
I used a foam brush and some Rustoleum from Home Depot... No, really.
Total cost of the project was $74.74 and it took about 10 days of my time.
The final result is amazing to say the least. Dont get me wrong, it is not perfect, but for $74.74 I would say it is a damn good job.
What do you think?
http://img.photobucket.com/albums/v326/StylussKid/Paint%20Project/DSC06185.jpg
http://img.photobucket.com/albums/v326/StylussKid/Paint%20Project/DSC06172.jpg
http://img.photobucket.com/albums/v326/StylussKid/Paint%20Project/DSC06165.jpg
http://img.photobucket.com/albums/v326/StylussKid/Paint%20Project/DSC06198.jpg
http://img.photobucket.com/albums/v326/StylussKid/Paint%20Project/DSC06178.jpg
Here is a link to the write up on how I did it:
Styluss Customs - Poor Man's Paint Job (http://www.stylusscustoms.com/poormanspaintjob.html)
I know some of you may have seen the $50 Paint Job out there, this is different. Yes, it uses some of the same principles, but an entirely different technique to help eliminate the need for excessive sanding. What you see here is NOT sanded and NOT polished in any way. I simply let the paint dry, washed it and waxed it.
I figured some of you might want to throw a coat or 2 on your rides. It really is an easy, inexpensive way to bring some new life back to your car!!
Styluss
11-14-2007, 11:52 AM
A method very similar to this is in this month's Hot Rod Magazine...
loosenut74
11-17-2007, 03:05 AM
the retta is looking good ryan...loosenut...
BerettaHatred
11-21-2007, 12:35 PM
I am blown away. Your car looks amazing for that amount of money. What was the condition of the body before you started? Was there a lot of sanding and body work involved?
Styluss
11-23-2007, 11:01 AM
Well, the body was actually just fine before I started. The paint however was not. All I did was wet sand the paint down with 600 grit paper before I started. Then I laid on 3 coats of paint and wet sanded again. Then 3 more coats, let it dry and wash and wax... done.
j cAT
11-24-2007, 09:41 PM
If you use very light colors this should come out good . I would not try black. very good job on applying paint evenly.how much did you thin the paint before applying. Did you use any primer ? I have used this paint on my patio furniture with good results and durability.
Styluss
11-25-2007, 12:18 PM
I did not use any primer, except for some small areas on the trunk lid where the paint had come off down to the bare metal.
And as for thinning... I used a mix of about half and half paint to mineral spirits.
HeWhoKillz
11-26-2007, 04:35 PM
Real good job. Nice solid color. Would blue be to dark to work with? How durable is it?
Styluss
11-26-2007, 11:20 PM
People say the white hides a lot of the "mistakes", but I could see doing this with any of the colors Rustoleum offers and having no issue. Even if you do get some stroke lines, so what? It is a great solution to a poor looking car in my opinion.
92v6beretta
11-29-2007, 08:17 AM
Looks Good ! I used the same on mine. My 92 had alot of bobywork. I ended up primering the whole car. The primer seems to have helped the paint to stick to the bumpers and moldings. My paint has been on for almost a year now and still shines.
loosenut74
12-20-2007, 06:32 PM
get reply Ryan....
http://forum.topspeedautogroup.com/
superdude6969
01-12-2008, 02:30 AM
Did you tape off any of the parts you didnt want to paint on? Great job by the way, real swell job.
Styluss
02-13-2008, 06:34 PM
I totally taped off the areas I did not want to get paint on. It was very easy and did not take much time at all.
diamond12f
02-13-2008, 06:50 PM
WOW, it looks perfect to me!:smooch:
Sandler007
04-10-2008, 08:09 PM
would a bit darker of a red be good?
Johnny Mullet
04-27-2008, 10:05 PM
I am painting my Metro with this same method real soon! I will post the results in the Geo Section when done.
Styluss
06-13-2008, 01:17 AM
I have recently updated my write up. There is now a six month update on how the paint is doing, as well as some more in depth tips to getting the job done.
Check it out!
http://www.stylusscustoms.com/poormanspaintjob.html (http://autoforums.carjunky.com/cgi-bin/gforum.cgi?url=http://www.stylusscustoms.com/poormanspaintjob.html)
S-fly
01-11-2009, 02:52 AM
Ha, it looks better then mine
Google
Web AF
