1993 F250 Fuel Pump Problem?
Google
Web AF
whud
11-12-2007, 04:12 PM
I have an 1993 F250 with 5.8L. I'm getting false cues that the tank is out of gas and the truck chugs. Switch tanks and it runs ok for a while then happens again. Switch back and I'm ok for a while. I changed the filters and still have the problem. ???
The Rider
11-18-2007, 10:52 AM
I have a 1992 F150 with duel tanks and when I use the rear tank the idle goes rough by that I mean stall then run, but when I switch to the front tank the problem diminishes a little but still does it. The truck runs well enough useing the first tank but I would like to have use of the second tank as well. I did replace the fuel pump in the second tank and there was no diffrence. Please help.....
78fordman
11-18-2007, 03:23 PM
what is your fuel pressure like try on the first tank then try it on the second.
The Rider
11-18-2007, 09:12 PM
I have a 1992 F150 with duel tanks and when I use the rear tank the idle goes rough by that I mean stall then run, but when I switch to the front tank the problem diminishes a little but still does it. The truck runs well enough useing the first tank but I would like to have use of the second tank as well. I did replace the fuel pump in the second tank and there was no diffrence. Please help.....Hi, it's me again. I replaced the coil like one of the earlier users and still no diffrence. Does anyone think this could be a ecu problem or a throttle position sensor.
Google
Web AF
