surging 82 320idgsmooth 12-02-2002, 04:10 AM i have an 82 320i and it surges under acceleration, even a little at idle.:confused: also, when i let it drop down from 3000 rpm or more on its own, it will stall. :mad: if i slow it down slowly with throttle or transmission a little, it will almost stall, and then go back to idleing perfect. :( i honed the block and put in new rings, and completly rebuilt the head and everything, and now i can't get it to run smoothly like it did before....i'm becoming very desperate.........:smoker2: :smoker2: dennisgehlen@hotmail.com chrisco2001 12-11-2002, 12:55 AM Probably your oxygen sensor if you go down from 3k rpm and then it stalls. Happened to me also have an 82' 320i, sweet little car. Good Luck! wally059 02-26-2003, 10:46 PM Mine was doing the same but it had a ruber hose broken, the one coming from the filter to the engine, you might want to check your vacum hoses while you try to figer it out. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
