1997 Plymouth Voyager Parking Brake?Krazy Jeff 10-31-2007, 04:38 AM The parking brake won't stay down. It just slowly (grinds) up. If I position it so it's up against the side panel, it will stay, but it's not good. Any suggestions how to fix this? Or should I hire a professional? I also think the release parking brake handle is torn off, because I don't see it where I think it should be. Is there a way to fix this also? Do you think I can purchse the replacement at a local auto shop? Or am I gonna have to make a trip to a wrecking yard? Picture of missing parking brake handle below: http://danceusapro.com//images/1997_Plymouth_Voyager/missing_parking_brake_lever.jpg dcx96 10-31-2007, 04:28 PM Climb Under The Van And Try To Adjust The Linkage You May Need To Play A Bit . Careful There Get Rusty That May Be The Cause. If It Is Above You Need To Buy New. RIP 10-31-2007, 04:39 PM The pedal assembly is what locks the brake in position. Sounds like the lock mechanism is shot. You may need a new assembly. You can read up on the system here to see if you want to work on it:http://www.autozone.com/az/cds/en_us/0900823d/80/1a/4c/b1/0900823d801a4cb1/repairInfoPages.htm A new plastic handle? Can't imagine it costing more that $15 at the dealership. There's always junkyards. Krazy Jeff 10-31-2007, 05:01 PM Thanks guys.. I just read the fix/removal instructions and I think I might just take it to a pro. I live in an area where there are a lot of steep hills, so I should take care of this very soon. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
