98 4.3 wont start unless depressing gas pedal slightlykeithblazer 10-29-2007, 06:58 PM truck wont start unless you hold gas pedal open slightly. after that it idles and runs fine. engine was replaced with a used engine 68k miles. is there a iac reset procedure thank you keithchevy 10-30-2007, 07:18 AM could this be a dirty throttle body or clogged iac passage? Chris Stewart 10-30-2007, 11:57 AM It makes me wonder about the TPS. keithchevy 10-30-2007, 04:04 PM tps voltage should be what at idle position? old_master 10-30-2007, 05:44 PM Not recommended to use voltage as a test. On a scan tool, TPS is measured in percentage open, should be zero % at idle. keithchevy 10-30-2007, 06:16 PM using mt 2500 scanner tps % is 0 at idle and reading .63 volts old_master 10-30-2007, 06:27 PM Check fuel pressure, key on engine off, fuel pump running. Or you can install a fused jumper wire from the battery to the empty, recessed terminal right in front of the fuel pump relay in the underhood fuse panel. Must be 60 to 66psi and remain above 55psi for several minutes after the pump shuts off. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
