Whirling noise
Google
Web AF
chigowolfs76
10-29-2007, 02:50 PM
Ok I know you all seen enough of this heading...
After reading so many comment on this noise I was like ok, I have a bad Fan Clutch... Well I replace it over the weekend ( about an hour ) and I started the truck... Still makeing same noise.....
To me it sounds like it is coming from the alternator... If is it going bad... could it make a like whirling noise?? This noise is coming from the driverside of the engine right around the alternator....
It is a '05 TB with about 45,000 miles the noise started about 4-5 months ago at the typical chevy squeek.... no more squeek, just whirling all this time...
Thanks
Scott
maxwedge
10-29-2007, 03:53 PM
Loosen or remove the bett see if it goes away.
chigowolfs76
10-29-2007, 04:00 PM
OK, and the best way to just loosen the belt???
16th hippy
11-05-2007, 03:10 AM
try the idler pulley....use a long screwdriver on bolt head attaching pulley with engine running(being VERY careful)...you should hear the rattle/grating noise through the handle. kinda common on those. if you buy the pulley and it has a bracket on it, just change the pulley, so much easier. let us know!
Google
Web AF
