My 4wd flashing light woes FIXED!
Google
Web AF
burnchassis3
10-28-2007, 07:29 PM
Well I seen I had a vacuum line off,but couldnt see where it went/goes,so I plugged it off today,and the 4wd went right in...just like its supposed to.
Here are 2 pictures of the line I plugged.The line is rotten..so this may be the cause of some others issues also..check it out !
99 blaze 4wd
http://i223.photobucket.com/albums/dd64/burnchassis3/100_1579.jpg
http://i223.photobucket.com/albums/dd64/burnchassis3/100_1578.jpg
CS
Chris Stewart
10-29-2007, 09:14 PM
Thanks for sharing BC3, it'll help somebody down the road.
Do you think that vacuum line might've fit the black ball mounted on the underside of the hood/drivers side?
burnchassis3
10-30-2007, 02:51 AM
Not sure myself...you'd know better then I would,BUT I will definately try and let you know.
Thanks
burnchassis3
10-30-2007, 04:14 PM
I checked under the hood today,I seen nothing where a hose can attach..no black ball..or whatever it is.
Anyone have any other Idea where this line might attach to?
Look up to my previous post for a picture.
Thanks!
CS
old_master
10-30-2007, 05:54 PM
It goes to the vacuum reservoir mounted in the left inner fender. Must remove the ABS unit to access it. Once the unit is out of the way, the reservoir just snaps into the inner fender.
burnchassis3
10-31-2007, 06:04 AM
Ok thanks I appreciate it ,I'll look today.
Can you tell me that lines precise function?
Is it is 4wd vacuum ? By plugging that line my 4wd started working again.
CS
Chris Stewart
10-31-2007, 09:01 AM
It connects to a vacuum tank that makes vacuum available when the motor is in a low vacuum condition such as wide open throttle or near open pulling up a steep grade.
Google
Web AF
