distributor question
Google
Web AF
y2kblazer
10-26-2007, 06:02 PM
hey! Is approx. a half inch vertical play (with a twist) too much play when you pull up on the rotor/ dist. shaft?
thanks.
old_master
10-26-2007, 07:39 PM
Distributor shaft end play should be .010 to .015
It can be adjusted with shims. The distributor must be removed from the engnie, and the gear removed from the shaft to install the shims.
blazes9395
10-27-2007, 12:52 AM
Why are you asking, do you have a problem with the truck? Do you mean when your pulling and turning it up/out?
y2kblazer
10-27-2007, 05:13 PM
the play is with the dist. still in the truck. Has 99.6k miles on it. I just noticed when i had the cap off, what i thought was excessive play -up & down - in the shaft. Since it can be shimmed, are there replaceable bushings or any seals to be checked also?
Google
Web AF
